Question for those who have removed their Smog pumps etc...
Old Oct 1, 2001 | 07:41 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Hey guys, I am getting ready to remove my smog pump, and allt the other junk along with it. I already removed the cat. There is no emission checks wher I am at in Florida. What size plugs do I need to block off the exhaust manifolds, where the pollution pipes went? And for those of you that did this too there car, is there any other helpful advice you can give me? How big of a job is this? Can I do it in a day??
Thanks dudes!
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Old Oct 2, 2001 | 01:36 AM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
it would be better to by a set of headers with out air pipes. and u will like the diff.
Old Oct 2, 2001 | 02:39 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I used 1/4" brass plugs. They didn't thread in very well, I think it was some pipethread thing. But they did the trick. It's a pretty easy job, I did mine in about a half hour. But I suppose if the lines are rusted into the manifolds it would make things more difficult. Better use line wrenches and some rust penetrant.
91 Z28
Come see The Vicious...
Old Oct 2, 2001 | 05:46 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
The threads in the stock exhaust manifold are some strange thread pattern for the those air tubes. Someone once explained it to me. It's more a plumbing type thread. I found some plugs at the hardward store that worked until I got my SLP headers on.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Oct 2, 2001 | 06:56 AM
Engine: ZZ4 - 350
OK guys, thanks for the advice!
Sounds good.
Later
Mike
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
redmaroz
Aug 16, 2015 11:40 PM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
