Erratic voltage readings
Old Oct 1, 2001 | 02:01 PM
89firebird's Avatar
Car: 89 Firebird Formula T-Top
Engine: SP383 FIRST Fuel Injection
Transmission: T56 Tremec Magnum
Axle/Gears: Moser 12 Bolt, 3.42 Eaton Posi
I've been trying to hunt down a gremlin in my 89 firebird, 305 TBI. The voltage at the gauge reads around 10-11 volts, but when I check it at the battery, it shows normal 12-14 volts. Somtimes the car will not start, but if I put jumper cables to it, it will start right up. I've replaced the alternator several times, the battery is a brand new Interstate and I replaced the starter just for grins.
I still have the same problem. What could be causing the gauge in the car to read low? Could it be some wiring, and if so what wires should I start looking at. Thanks for any help....
Old Oct 1, 2001 | 02:46 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The guages in our cars aren't the most accurate. As long as you don't have problems starting your car or alt. squealing I wouldn't worry about it.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 1, 2001 | 02:59 PM
mvftw's Avatar
I had the same problem in my '95 Astro. It turned out to be the Alternator.
Old Oct 1, 2001 | 03:26 PM
89firebird's Avatar
I am having problems starting the car. The only way to get it to start is to put a charger or jumper cables to the battery. I'm confused because at the battery the voltage reads good. I'm not sure if the gauge is just a coincidence, but it seems like the battery is not charging enough to crank the starter. Should I look at replacing the cable to the starter and the battery? I've been fighting this thing for over a year. Just when I think the problem is fixed it comes back to haunt me...
Old Oct 1, 2001 | 05:13 PM
Bjase's Avatar
Car: 88 IROC
I would guess the connection at the starter is OK, since you say you changed it. Definitely put a new cable on it. Get a new ground cable, too. Shouldn't be that expensive or difficult. Check to be sure you have good, clean connections all around.
I wouldn't worry about the gauge for now. Mine reads all over the place. I drove around with a voltmeter plugged up to the cigarette lighter to assure myself it was just the gauge. (It was)
88 IROC with cobbled together (not by me)drivetrain, 86 (?) TPI unit on an '83 305,CE subframe connectors, Edelbrock strut tower brace, polygraphite bushings all around...it handles like a dream, but man is it hard to push!!
Old Oct 1, 2001 | 06:06 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
Possibly a bad ground like bjase said.
When you say it doesnt start what does it do? click click or nothing? I've had problems in the past with those cheap *** rebuilt starters from pep boys. Could be a possibility.
My Website
92 RS, 350, Street & Performance MPFI, TFS heads, Stock crank and rods, Fordged flat tops,
Crane Rollers,
MSD Digital 6 Plus, 22lb injectors,
ZZ3 cam, Edelbrock Headers 1 5/8, 3" Exhaust,
Hi Flow 3" Cat, stock T-5,
stock rear 3.08, koni yellow adjustable front, twin turbo glass hood, T-tops, Auto Meter Ultra Lite Series 2 5/8 gauges, Teal Green
Est. 365Hp 420+Lbs.
Old Oct 2, 2001 | 10:00 AM
89firebird's Avatar
No it doesn't click, it just doesn't start (brand new AC Delco starter). It just occurred to me that when I use jumper cables to jump start the car, aren't I adding an additional ground cable? Maybe it is the ground cable. I'll try that and let everyone know. Thanks for all the advice.
Bubbajones_ya
Jul 6, 2024 08:32 PM
MM2Robinson
Oct 1, 2017 09:16 AM
BumpaD82
Feb 26, 2016 02:57 PM
eustodp
Sep 20, 2015 05:09 PM
RyanJB
Sep 2, 2015 01:27 PM
