cleaning up the engine bay
Old Jul 29, 2005 | 01:38 PM
bad324's Avatar
Car: 89 Iroc
Transmission: t-5
Well I have been reading up on The A/C delete and the Smog delete mods. Eventually I will be doing those when I get the pulleys and also understand it all 100%. Is there anything in the engine bay that I can get rid to clean it up that doesn't require replacement parts? I've got some extra time today and tomorrow and thought I would look into this. It is not a daily driver, just a summer fun car that eventually we would like to turn into a show car.
Old Jul 29, 2005 | 01:42 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
You can actually just remove your smog pump and buy a smaller belt.
Old Jul 29, 2005 | 01:44 PM
bad324's Avatar
Car: 89 Iroc
Transmission: t-5
I saw that but I wasn't a huge fan of the gaping whole, I like the way the pulley looks in there.
Old Jul 29, 2005 | 05:08 PM
MNformula350's Avatar
Get rid of all the emissions and A/C garbage, I removed the stock radiator overflow and washer fluid bottles and replaced them with a combination unit from a 1991 Ford Explorer, that in my opinion made a large differance. Also since my car is speed density I was able to get rid of all the air filter intake stuff and replace it with the 1000cfm Cone filter on the end of the throttle body, I also removed the charcoal canister, and that is where I ended up mounting the Exploder bottle assembly.
Future plans call for moving the battery to the trunk when I install my new 3:73 posi rear to aid in both weight transfer and removing more engine bay clutter. I am also trying to find a way to completly remove the bracket with the tensioner on the passenger side of the engine.
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
