Trouble with A/C
Old Jul 30, 2005 | 06:54 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Trouble with A/C
When I turn on the A/C the clutch on the compressor will cycle on and off every 10-15 seconds.
As far as I can tell the air is noticeably colder...although it seems like its not as cold as it should be. Its pretty hard to tell since its hotter than hell where I'm at and the T-tops and black vinyl dashboard make for a pretty good greenhouse effect.
I'm probably gonna take it in to an A/C service shop for an inspection. Any ideas on what to check or what the prob may be would be greatly appreciated. This way I'll know if the mechanics are trying to rip me off.
Old Jul 30, 2005 | 08:58 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Well theres only two possible causes for that. Either the system is still 1/2lb low or the pressure switch thinks its low.
Old Jul 30, 2005 | 09:07 PM
Pukka's Avatar
Its been quite awhile since the last time I had the A/C recharged.
Thanks for the tip!
Old Jul 31, 2005 | 08:29 AM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Have you checked the air temp coming out of your vents using a thermometer. Check that temperature against the recommended temp listed in your manual. It should be somewhere between 45-65 degrees.
jrdturbo
Mar 31, 2016 02:58 PM
mrbird
Oct 20, 2015 03:43 AM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Lmancha96
Sep 25, 2015 08:11 PM
