rear end question
Car: 1991 camaro rs
rear end question
3.73 posi rear w/ disc brakes (3rd gen) needs spring for posi has new brakes
this is the rear i am hoping to pick up in the near future for my car....how hard of a replacement is the spring for the posi? i haven't ever messed with rebuilding a rear end before and have only had the cover off one off for long enough to add a rear end girdle
easy task or something i should leave to someone else?
Car: 1991 camaro rs
from what i have heard i just have to replace one of the yellow springs in there
you 100% that i can't just put a spring into it and the rear would work?
you 100% that i can't just put a spring into it and the rear would work? Originally posted by jazzcat2001
you 100% that i can't just put a spring into it and the rear would work? If that was the case there wouldn't be so many unoperable LS out there. Do a Seach.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
