...the saga continues...
Old Aug 1, 2005 | 10:48 PM
POS350Z's Avatar
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
I took the MSD box off the car and got it back to the stock set up...went to fire it up...and........VAROOM!!! she roared to life...after throwing my arms up in victory the car stumbled and died.... ....so I thought timing problem...twisted the dizzy around....got a couple burbs outta the motor then just pulled #1 spark plug put a rubber glve in the hole bumped the starter and saw the glove blow out (I'm working solo)...droped the dizzy in on #1 and now there ain't nothing...she ain't even trying to start......the big thing is that I think I fixed the ignition system....the manual says when setting the dizzy put it between 1 and 8.....do I do that or should I go to 1...
Old Aug 1, 2005 | 10:59 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
try one thats how I did my 305, if you have a next door neighbor or gf. Have them crank it till it hits the tdc of the #1 cylinder. Do this by reading the timing marks on the balancer. Put in the dizzy, if this doesn't work you maybe 180* off. IE rotate the assembly 1 time
Old Aug 1, 2005 | 11:09 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Keep in mind there are 2 TDC's in a combustion cycle. Compression and exhaust. Use the friend or get/create a starter interupt switch (handy if doing solo work) and put your finger or the butt of a screwdriver over the #1 hole. When you feel pressure behind it, look at the valves and the balacner. If both valves are fully closed when you hit TDC, you are on the compression stage, and #1 is firing. If the exhaust is open when the balancer reads TDC, #1 is on exhaust and #6 is firing.
Old Aug 2, 2005 | 10:03 AM
POS350Z's Avatar
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
SHE RUNS!! You guys have been a huge help..thanks....my friend came over and we set TDC and she fired right up!! The comp cams XFI 292 sounds bad a$$ at idle....don't know if I'll be any faster .....wow wierd how my MSD box and ESC would take a dump during my cam swap.....anyways thanks again!
350Z
Old Aug 2, 2005 | 02:56 PM
Scrote's Avatar
Hey Trev, thats sweet man....glad she is running for you, i got the email, and if you have any more problems give me a ring.
Peace man,
Erik
llvll4l2c91350
May 11, 2005 04:07 AM
FruityOne
Apr 27, 2004 12:18 AM
SlowMaro
Jun 25, 2003 11:25 PM
si_camaro
Mar 31, 2003 02:37 PM
PontiacV8
Dec 29, 2002 07:28 AM
