HELP ....servo install
Old Jun 25, 2003 | 05:13 PM
SlowMaro's Avatar
ok wtf wont this F$%^KING bell housing depress in fully!!!!!
ok so the writting on the outter plate faces towards the inside of the bell housing correct??
i took the spring/plate out the old servo , put it in the new one, ...the plate is facing the last spring.
this is correct? then the top part of the servo is connected to that, ...the T shaped ridges are facing towards the bell housing...
Correct??
then spring, washer, retainer...
then the plate, then the bell housing....plate with the writting on it is facing towards the inside of the bell housing....
Correct?
please help quick, sun will be down in 2 hours, ...must have this crap done!
Old Jun 25, 2003 | 07:23 PM
SlowMaro's Avatar
heh ok RE post....its in, all is good, ...may have clippied the oring putting it in though....might have small small oil leak, if so , ill pull it off tomarrow...
for anyone who hasnt done this and lpans on doing it, its a BITCH to set the bell housing back in, ..youll need a crow bar and push it forward instead of pulling backward like i did for an hour....
just make it your bitch, and itll go in.
other than that i highly reccomendd this mod. my car has a reman tranny with 500 miles on it, gm stock rebuild, and i put this sucker in....chirps the tires going into second every time....
well worth the 15 bucks i paid for it and the 3 hours it took to set it all in right...
:rockon:
Old Jun 25, 2003 | 11:25 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Not a Preachers mod that's for sure.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
