XM262H vs. XE262H
Old Jul 31, 2005 | 03:48 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
XM262H vs. XE262H
Toss up between these two cams.
Stock TPI heads, ported, lightweight LT4 valvetrain. 1.5 Rockers.
Holley Stealth Ram intake
9.5:1 compression.
350 .040 over.
Leaning towards the Marine cam because of the LSA of 112 vs the LSA 114 of the XE cam.
XM262H
262/268 duration
.462 intake .477 exhaust
112 LSA
I thought this might be beter because it has more lift on the exhaust side.. beter for stock heads?
XE262H
262/270 duration
.464intake/ .470exhaust
LSA 114
Opinions?
Should both of these run on a stock tune? (I will tune it after)
Is there going to be any noticable difference between the 114 and 112 lsa camshaft?
Old Jul 31, 2005 | 05:46 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Doesn't the xe262h have a LSA of 110*... Nevermind your tallking about the XE CC cams and the XM grind.
I would go with the XM grind because it has a smaller LSA which will increase low-end a tad.
How about XE 4X4 cam X4262H
X4262H
262/270 duration
.462intake/ .480exhaust
LSA 111
It would probably be the best for the stock heads, which have weak exhaust ports.
Old Jul 31, 2005 | 05:57 PM
X4262H
262/270 duration
LSA 111
I was looking at the 4x4 Cam but I thought it may have issues with the computer. My tuning ability is currently limited, as I am just learning.
Old Jul 31, 2005 | 06:47 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I doubt you will have any problems those cams are so small that they don''t have much overlap or duration anyway.
3.8TransAM
Sep 17, 2015 02:16 PM
Danger
Nov 5, 2001 04:13 PM
Danger
Oct 25, 2001 12:04 AM
camaroguy99
Aug 29, 2001 12:46 PM
