No spark after cam swap!
Old Jul 31, 2005 | 07:13 PM
POS350Z's Avatar
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
.....set the dizzy to be sure I wasn't 180 out....car has good comp...blew my buddies finger out of the hole.....I can hear the fuel pump and smell it.....we tested the #1 plug....nothing....tested from the coil to the dizzy nothing...took the pcms for less chip out and swaped in the stocker...nothing....both connectors are hooked up to the dizzy....WTF is wrong? What am I missing?????
350Z
Old Jul 31, 2005 | 07:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Did you plug the coil wire back in?
Old Jul 31, 2005 | 07:50 PM
POS350Z's Avatar
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
yes the coil wire is pluged back in....can you test the dizzy...or the coil?
Old Jul 31, 2005 | 07:57 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
When you bumped the motor to #1 TDC did you align the crank so it was at the 0° mark on the timing tab? Did you then varify that the #1 plug wire terminal was in line with the rotor in the distributor? I would double check that you are at TDC and I would also tripple check that you didn't get any wires crossed.
Old Aug 1, 2005 | 12:15 AM
POS350Z's Avatar
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
shifty..yes to all of your questions...I set the dizzy via the manual...I've done it before and it worked like a champ....there is NO spark...from the plug or the coil.....I swaped in a new dizzy after auto zone found the ESC to be bad....they also tested the coil and found it to be slightly out of spec....they were measureing resistance..the book said the minimum should be .6 ohlms my coil was .57....I thought because its an MSD coil it would be OK...am I wrong??? There is no ignition fuse is there?.....just completely stumped HELP!!
350Z
anesthes
Mar 10, 2016 10:35 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
cstrobel65
Aug 15, 2015 10:19 AM
