Ordering Pushrods. Which Brand?
Old Oct 4, 2001 | 09:11 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'm getting the 7.300 for my setup heres the list.
Comp = $35.95
Trick Flow = $84.50
Crane = $109.95
Lunati = $135.98
One of my friends had a Comp bend on him so I'm leaning away from that brand. summit doesnt seel there brand for Hyd Roller.
Old Oct 4, 2001 | 09:48 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I have Trick Flows. They are nice and one-piece .
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Oct 4, 2001 | 10:33 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Check out the LPE pushrods. They are $35.
92Z28
89GTA
Old Oct 4, 2001 | 10:38 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Comp has 2 different grades of push rods. The lesser ones (the ones you refer to) are a relatively small step up from stock. The others are similar to all those other brands in quality and price.
Whether you really need the others depends on the rest of your setup; and on whether the very limited choice (mostly stock ones for various motors) in the cheaper line has the right length for you. IIRC the 7809, the stock one for roller systems which is probably the part # you got a price for, is actually 7.290" long, not 7.300". Their premium product comes in .050" increments over a very wide range including 7.300. I use those, except I always seem to need lomger ones; IIRC the ones in the motor I have now are 7.400". They cost about $90-$100.
ICON Motorsports
Old Oct 4, 2001 | 10:49 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Jegs hooked me up with some Crane hardened ones for about 30 smacks. They are hardened for use with guide plates. I think they were called energizer series or something but don't hold me to it.
dbrochard
Sep 19, 2015 08:13 PM
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
