Hydrocarbon Emissions HELP!!!
Old Oct 5, 2001 | 11:12 AM
Fastcamaro87's Avatar
Ok heres the story, i took my car for inspection and the only part of the emmisions test that it failed was the :
HC ppm reading at idle which was 338 and the limit allowed was 220 .
does anyone know how i can get this reading down? i am going to change the plugs and all my other ignition components are new so they are not likely the problem, any tips or tricks to get this number down to an acceptable level? even if its only gonna last long enough to pass the test, cause thats all i really need to do. thanks in advance
87 IROC-z 305 TPI
Borg Warner T-5 fresh rebuild
10-bolt 3.73 Richmond gears rebuilt GM posi,
Ported Plenum and Runners Homemade AFPR
ACCEL 8.8 wires, High output coil,and cap & rotor
Bosch platinum + 4 plugs
Ram Air w/ K&N filters,
MAF sensor screens removed, TB coolant bypass
Polyurethane tranny and torque arm mounts
Dynomax catback w/custom tips
K&N oil filter,Mobil 1 synth, Futura GLS Super Sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Old Oct 5, 2001 | 05:31 PM
dudelovett's Avatar
Try changing your O2 sensor. That got me through after I failed on hydrocarbons. Also make sure your cat is functioning at its fullest capacity.
Derek
Hotrodboba400
Dec 10, 2019 07:07 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
TBRays98
Sep 6, 2015 05:05 PM
