Fuel sending unit install
Old Aug 4, 2005 | 09:08 PM
qwik92rs's Avatar
Car: 1992 Camaro Heritage Edition
Engine: 305 TBI
I need to replace my fuel sending unit and I have never attempted this before. What's the best way to do this?
Old Aug 6, 2005 | 12:47 PM
qwik92rs's Avatar
Engine: 305 TBI
Anyone?
Old Aug 6, 2005 | 07:45 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
Get the car in the air, pull the bottom nuts off the shocks to lower the rear. Pull the springs out. Remove the gas filler cap, door and plastic housing.Disconnect all 3 fuel lines. Take the 2 15mm bolts off the gas tank straps and with a jack, lower the gas tank. Unplug the harness connector somewhere in there too. Once the tank is down, use a hammer and a punch to tap the lock ring around the sending unit loose. Pull the sender out.
Old Aug 6, 2005 | 08:06 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
DO NOT hack into the hatch area to get at it unless you plan on spending some significant time to do it properly... which I doubt you will. I think I've seen ONE done properly on this board.
Old Aug 6, 2005 | 09:02 PM
qwik92rs's Avatar
Engine: 305 TBI
Thanks for the help everyone. I guess i'll try it later this week and see how it goes.
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
hectre13
Aug 26, 2015 08:17 AM
Irocohio
Aug 12, 2015 08:03 AM
