What should be my next mod?
Old Oct 5, 2001 | 11:54 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I was thinking of either getting a Performer Intake or could my engine benefit from a super coil by Accel, I think that's what it is called that allows more spark over 4500 rpms. However my redline is at 5200rpm and the car stops pulling around 4700 rpm. Is this due to the stock coil.
Another thing to consider is that I am off at college and hardly know squat about working on cars. So my brother would be doing this, and I'm sure he would much rather put the ignition part on than an intake, so which should I go for?
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 6, 2001 | 01:18 AM
LastHopeRS's Avatar
i only got a 305 my man, but...i just got the accel super coil and it is a nice little thing. its also fairly cheap, and a cinch to put on. its up to you what to get...just backing the idea that the accel should def. be kept on the option list. its just my 2 sense. later
BTW, my buddy has it in his 87...or is it 88(i can never remember)IROC and he is always smilin about it.
[This message has been edited by LastHopeRS (edited October 05, 2001).]
Old Oct 6, 2001 | 07:57 AM
92Camaro305TBI's Avatar
Hey Mark, what are you running in the 1/4
I'd go with the coil first...
Old Oct 6, 2001 | 09:02 AM
Car: 99 Formula
Axle/Gears: 342
I've never been to the track but I have G-Teched it, last time I did it was with 2:73 gears, no cat-back, and a severly slipping tranny (would hang up on 1-2 shift, and flare on 2-3 shift), it ran 15.61 @ 93mph. So I figure I should be in the mid 14 sec. range right now.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
160* Stat
3:73 Posi
Rebuilt 700R4
Old Oct 6, 2001 | 03:42 PM
84TransAm's Avatar
Maybe put on an intake. A edelbrock performer or performer RPM, it's not listed on your sig, that would be a good way to pick up some extra horses.
1984 Trans Am, Goodwrench 350, TES Headers, Performer RPM Intake, Flowmaster 80 Series, Holley 600 cfm & vacuum advance, and T5 with short shift
Old Oct 6, 2001 | 08:58 PM
Dan87IROC-Z's Avatar
I would for sure go with the intake. As long as all your ignition system components are in good shape, you shouldn't need a better coil with the set-up you have now. The reason the car only pulls to 4700 is because it can't breathe above that. I would bet that the intake could take a good .2 to .3 off your 1/4 times!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Oct 6, 2001 | 11:50 PM
Car: 99 Formula
Axle/Gears: 342
Wow, you really think the intake could help that much, if so I am definately going to get that. Which would do you think would be best I was looking at the Performer or Performer RPM, I don't have the summit catalog right here and I thought they differed by the power band. My car really starts to pull around 2600 rpm.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
160* Stat
3:73 Posi
Rebuilt 700R4
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
