Mysterious leaks
Old Oct 7, 2001 | 07:59 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Mysterious leaks
I was cleaning my car today and noticed a very small puddle of oil sitting in the area where the intake meets the head and was pretty sure that it was just a leaking valve cover gasket and an easy fix. After starting the car for the trip home I noticed a small puddle of antifreeze sitting at the front area where the intake meets the head. Now I'm worried. I brought it home and raised the hood to see if it got any worse and it was completely dry at both places! Is it possible my intake(Edelbrock aluminum)is slightly warped enough to cause a leak when cold and sealup when hot? Am I looking at replacing the intake gaskets or worse?
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,high flow cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit and torque arm,MacEwen White face gauges,84 T/A cold air induction air cleaner,Grant Formula GT wheel.
Old Oct 7, 2001 | 10:21 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
As far as the coolant, check the water outlet, they often will leak cold and not hot.
The oil, if its collecting around the intake bolts, is coming up the threads. Use a teflon type sealant on them when installing them, like PST sealnt from loctite.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
RS Reaper
Oct 17, 2018 07:52 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
Gordonr1973
Sep 29, 2015 11:59 AM
mfp189
Sep 27, 2015 09:25 AM
