I lost TCC lock-up... why?
Old Oct 8, 2001 | 09:32 AM
Xenodrgn's Avatar
I've had it just'unlock' on me while I'm crusing, but then it'll lock up again... well now after a TV cable reset (holy crap, I'm driving a new car) and a computer reset, I've lost it all together. How come?
I know the fluid is burnt, brown and gritty, and will need to be completely rebuilt relativly soon, but should that cause my TCC to die? perhaps my CTS is on it's way out?
(in a way it's nice driving it this way, because when I step on it, it's immediate get-up-and-go, whereas before I had to wait until the TCC would unlock.)
So what are some suggestions?
1985 Camaro SC - 2.8L, auto.
C'mon, spin 'em for papa...
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Oct 8, 2001 | 01:45 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
The solenoid went bad, the wiring went bad, or the ECM/it's driver went bad.
-Put a paperclip in the ALDL between terminals A and F (top right and left corners) and drive it. The TCC should lock as soon as it shifts to second giving you a big bog. If so, the problem is the ECM isn't trying to turn it on.
-Verify 12V at the connector on the tranny (consult manual for which is the TCC + wire) If no power, either the wire is broken, the fuse is bad, or the brake switch is bad.
-otherwise, you're replacing the TCC. You'll have to remove the old one to get the PN you need to order as there are a bunch of different tranny wiring styles.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.8 @ 93.1
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Oct 8, 2001 | 05:41 PM
Xenodrgn's Avatar
Cool, thanks Ed. I'll check it out.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
92camaro350cci
Oct 14, 2015 09:29 AM
Jynx88
Oct 4, 2015 08:19 PM
ramicio
Sep 28, 2015 01:18 PM
3.8TransAM
Sep 27, 2015 08:37 PM
