[PA] Cold start injector and rail fitting OR chip burned
Car: '87 Flame Red/Carmine Red GTA
Pretty self-explanatory in what I need... It doesn't matter if the metal tube between the two are messed up...I have that. Anyone local have these?
EDIT: Instead of an injector, I could also be looking for a chip to:
1. Add the cold-start functions
2. have the TCC lock up at a certain speed
3. Lower the temp. the TCC can lock up (or disable this "feature")
4. Remove the AIR functions
And how do the chips work? Do I just solder in a socket, or do I need to send a person the whole assembly that plugs into the ECM? I can't do the latter. It's my daily driver.
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Ram, let me see if I have one floating around. I think I do.
Sent from my iPhone using IB AutoGroup
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Cold start injector and rail fitting OR chip burned
Got this: Blasted and primed,......
Send me an offer if your interested.
I am waiting on a chip to be sent out. I'll reply if it doesn't work out 100%.
