Rod Question on a 383 or 388
Old Oct 8, 2001 | 02:13 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
I'm planning on building a 383 or a 388 (w/3.80 crank) my question is about the rods, how much grinding is needed to install the aluminum big end rods? Will they be too big?? Or the H or I beam rods look like better idea?
My Website
92 RS, 350, Street & Performance MPFI, TFS heads, Stock crank and rods, Fordged flat tops,
Crane Rollers,
MSD Digital 6 Plus, 22lb injectors,
ZZ3 cam, Edelbrock Headers 1 5/8, 3" Exhaust,
Hi Flow 3" Cat, stock T-5,
stock rear 3.08, koni yellow adjustable front, twin turbo glass hood, T-tops, Auto Meter Ultra Lite Series 2 5/8 gauges, Teal Green
Est. 365Hp 420+Lbs.
Old Oct 9, 2001 | 06:27 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
Aluminum rods are really not good for the street. Get a good quality H or I beam.
Old Oct 9, 2001 | 07:05 AM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
Thanks for the reply jc, but that doesn't answer my question. I know the aluminum rods have a larger big end, will I be able to use them? or will there be too much grinding involved?
Old Oct 9, 2001 | 07:16 AM
ede's Avatar
ede
to take it a step farther from what jcb said the aluminum rods aren't for the street, they grow too much after a short time. if you want to use them it isn't a problem, just have your block sonic checked and fill the bottom 1" with grout so there is no danger of a leak.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Mickeyruder
Sep 2, 2015 02:45 PM
lt1z350
Aug 28, 2015 05:57 AM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
redmaroz
Aug 16, 2015 11:40 PM
