Harmonic Balancer
Old Aug 10, 2005 | 03:26 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Harmonic Balancer
Hey guys, my harmonic balancer ring has slipped so I want to replace it. How hard are they to install?
Old Aug 10, 2005 | 03:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not terribly difficult. You'll need a puller and an installer to do it. The puller you can buy or rent, the installer you can buy, rent or make.
Old Aug 10, 2005 | 03:37 PM
ede's Avatar
ede
with the right tools, real easy
Old Aug 10, 2005 | 03:45 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Sounds good I will probably go ahead and do it myself then. Im sure Autozone could probably rent me the tools I need. What exactly is involved in taking it out and installing one?
Old Aug 10, 2005 | 03:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Take the accessory belt(s) off, take the pulley(s) off, remove the water pump, remove the balancer bolt, bolt the remover onto the balancer, turn the forcing screw until the balancer is pulled off.
Lightly lubricate the crank snout, slide the new balancer on until it stops, thread the installer fully into the crankshaft, turn the forcing nut until the balancer bottoms out on the crank, remove the installer, reinstall the balancer bolt, water pump, pulley(s) and belt(s).
Old Aug 10, 2005 | 04:30 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
but leave the water pump on.
Old Aug 10, 2005 | 05:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I originally posted it without taking the water pump off, but then I couldn't remember if it needed to come off or not.
Old Aug 13, 2005 | 11:32 AM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
looks like this thread has been handled.
Old Aug 13, 2005 | 10:14 PM
Lo-tec's Avatar
Old Aug 13, 2005 | 10:18 PM
Car: 1989 Camaro
Old Aug 13, 2005 | 10:40 PM
Lo-tec's Avatar
Old Aug 13, 2005 | 11:06 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
perhaps its time for the mods to ?
Old Aug 14, 2005 | 08:46 AM
Car: 1989 Camaro
I feel so cheated. Usually threads go on for days, but this one was handled so quickly and efficiently. I guess I'll just have to accept it and move on.
Old Aug 14, 2005 | 08:59 PM
Lo-tec's Avatar
...yes, time for a
Old Aug 15, 2005 | 03:11 PM
Car: 1989 Camaro
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
