In tank fuel pump intall question:
Car: 1987 Formula 350
Engine: TPI 350
I'm getting ready to replace my stock GM fuel pump with a Walbro unit. How easy (or hard) is it to remove the fuel tank? Can I get it out with out messing with the rearend? Any Tips?
Thanks, Dan
Thanks, Dan
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Jack up car as high as you can go, disconnect shocks from rear end, and remove panhard bar and brace. Lower rear end as far as you can go. Remove rear section of exhaust with the shields. I also remove the filler door and plastic piece around it. Once thats done, disconnect lines and wires and lower tank.
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
