Oil leaking from behind plug!!!
Old Oct 9, 2001 | 07:36 PM
Vomex's Avatar
I was under my car looking at a few things and i noticed that my number 7 plug was covered in oil. I know that is not coming from above because there is that metal plate just above it. I tried to tighten it by hand and it wouldnt move so i dont think it is loose. What does this mean?
Later,
Vomex
'89 GTA 5.7L TPI
Old Oct 9, 2001 | 07:52 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
It means you aren't strong enough. The correct torque to tighten the plugs (from HELM's manual: (V6) 25 ft-lbs, (V8) 22 ft-lbs. You are getting blow-by past the plug because they aren't tightened enough.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Oct 9, 2001 | 08:18 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You should tighten all plugs with a socket or wrench, but the fact that oil isn't leaking thru any of the other plugs doesn't make sense. I thought there was an engine condition where oil gets on your plugs, but I forget what it's called.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 9, 2001 | 09:22 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'd bet money your left valve cover leaks... there's no "metal plate" that would keep oil from the VC from getting down there. When the VC gasket leaks, the oil usually runs along the rail to the rear of the head and runs down at the rear, which of course means the #7 plug gets saturated.
ICON Motorsports
Old Oct 10, 2001 | 08:26 AM
ede's Avatar
ede
i'm with rb, again, i think the valve covers leak.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
LittleFranks
Sep 17, 2015 12:22 PM
Navy8125
Aug 21, 2015 09:32 AM
Exxon Limited
Aug 9, 2015 08:13 PM
drathaar907
Aug 6, 2015 04:20 PM
