Fuild capacities?
Old Aug 13, 2005 | 03:27 AM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
Fuild capacities?
i need the following fuild capacities for my car
ATF
Coolant
Differential fuild
thank you in advance.
Old Aug 13, 2005 | 08:13 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
My manual says:
Engine oil [with filter] 5.0 quarts
Coolant [1985 on] 17.2 quarts
Diff 3.5 pints approx
Old Aug 13, 2005 | 08:41 AM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
According to the manual :
3.5 quarts for the 200-C
4.7 quarts for the 700-R4
V8
84 & earlier 15 quarts
85 & later 17.2 quarts
2.8l 12.5 quarts
3.1l 14.8 quarts
L4 13.0 quarts
Rear Axle is 3.5 pints
Approved lubricants are GL-5 gear lube, SAE 80W or 80W-90
(NOTE If you have a limited slip differential you need to add 4 ounces of limited-slip differential additive when you change the lube.
Hotrodboba400
Dec 10, 2019 07:07 PM
krisb410
Mid-Atlantic Region
Mar 11, 2016 09:21 PM
rubyred88
Sep 17, 2015 02:19 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
loomdog32
May 1, 2002 10:21 AM
