LT4 hotcam or Crane 119831
Old Aug 13, 2005 | 12:51 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I've been considering the hotcam except for the fact you need an additional $100 for the 1.6 rockers to achieve the .525/.525 lift. So I also found this Crane Cam that has a little less intake lift but a little more duration at 0.05:
http://www.cranecams.com/index.php?s...31&lvl=2&prt=5
What do you guys think? Could the extra duration make up for the less lift up on the top end?
Old Aug 13, 2005 | 01:48 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
what kind of heads/intake are on the car? If they don't flow any air past .500", then there's no point on a cam that's got .525" lift.
Old Aug 13, 2005 | 02:30 PM
11 Flat's Avatar
I would use the 831
Old Aug 13, 2005 | 03:14 PM
mdricken's Avatar
Car: 92 Camaro
ZZ4 heads. The motor is still stock.
Old Aug 14, 2005 | 08:31 PM
bowtienick's Avatar
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
that seems really similar to the cam i am considering, except mine is a solid roller
Old Aug 14, 2005 | 09:14 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
If the ZZ4 engine (pardon my lack of knowledge) has the factory style roller cam that uses the 2 bolt retainer plate you'll need a new timing chain set. And you'll have to use a cam button with the Crane cam. That may also require a new timing chain cover that doesn't flex as much as a stock cover.
And just so you know, you don't "have to" buy 1.6 rockers. 1.5 will still give you .492" lift at the valves.
Just a few things to add to the cost difference.
Hotrodboba400
Dec 10, 2019 07:07 PM
thekurlyone
Sep 30, 2015 12:54 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
