Engine block code
Old Aug 14, 2005 | 01:50 AM
creepingdeath's Avatar
Car: 84 Z28
Engine: carb 305
Engine block code
My egine code is 3970010what does this tell me? i looked on a website to see what it meant and all it siad was some high horsepower and low horsepower numbers RPO i have no clue what it meant it also siad its a car,trauck or corvette block. does this code tel me the litres? im not sure if i have a 5.0 or 5.7 litre. And if it doesnt say that in the block code does anyone know where i could find a code on the engine to tell me the litres.
Old Aug 14, 2005 | 07:30 AM
ede's Avatar
ede
www.mortec.com
fact that it listed a vett makes me think it's a 350
Old Aug 14, 2005 | 08:18 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
010 castings just tell me that it's a common and normally a very good 4" bore block (302, 327, 350). The casting was used on just about everything. You need the suffix code to find what it was originally in. The suffix code is stamped on the pad in front of the passenger head. It's usually hard to read. If the block has ever been decked, the suffix code will be gone.
Chances are it's a 350 (5.7L). If it was originally out of a truck, it's probably a 4 bolt main.
Old Aug 14, 2005 | 09:27 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
My 3970010 block is a 350 4-bolt non-roller. All 010 blocks were non-roller and 2pc RMS. I believe the 010 blocks were the strong 'high-nickel' castings.
Old Aug 14, 2005 | 04:06 PM
Car: 84 Z28
Engine: carb 305
Ya ive tried to look for the suffix code but it doesnt have one. ad just last night i found the block code. i buaght the car from this old man he siad he pulled it from a 1977 Z28 and that it was a 350 5.7L im pretty sure thats what it is but i dont know for sure. the whol engine is like a dark baby blue colour nd its definatly original becuase the paint is super old ive never sen any cheyv 350's that are blue theyre all red or orange does that tell me anything?
Old Aug 14, 2005 | 05:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They were blue from the mid-70s until the early 80s.
Old Aug 14, 2005 | 05:40 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Sounds like it's still original. The suffix code should be still on the block. Get in with a scraper and wire brush to remove dirt/grime/paint until the numbers appear.
The 010 casting won't be a 305. It's unlikely to be a 302 or 327 with a blue block so that means it's going to be a 350.
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
