Engine codes
Engine codes
I just picked up an engine that is supposed to be from a 87 camaro and I was wondering if anyone could help me find out what it came out of. The casting numbers are as follows:
GM 5.0LG and SGI on the drivers side/left
14093627 on the right
The heads are cast with 14101081 and K187
Any help will be greatly appreciated as it will be going in my 88
Does it have a Carb or Fuel Injection if it fuel injection is it TPI or TBI
TPI come in Irocs and Z28
CrossFire comes in RS
Carbs come in SC
But Thats not always true
Good Luck,Hope that helps some what
**Chevy Let Camaro's Live**
Carbs come in SC
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
14093627 305 87-91 2 bolt Roller cam, one-piece rear seal
Without the suffix code, you won't know exactly what the engine came out of but it probably is from a 1987 just from the casting number. The suffix code is stamped on the pad on the block in front of the passenger head.
Heads are 87-95 305 castings.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The suffix codes are stamped on the actual block deck surface where the heads bolt on. Find the passenger side head, then find where the front of it meets the block. The suffix code is right there.
Now its possible that the engine has been rebuilt and the codes are gone. In that case it doesn't matter where it came from its not stock any more.
