Which fuel pressure gauge w/ my setup?
Old Oct 11, 2001 | 12:10 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
I've got a Walbro 190ltr/hr pump, Mallory 3port fuel pressure regulator (3-12psi), Holley 670cfm Avenger Carb. The FPR did not come with a fuel pressure gauge. Which gauge would you guys recommend that will work with this setup? btw, i am converting from TBI, and that's why i have an EFI pump. thanks
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, no cat,SLP 1 5/8" headers and y-pipe March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears(open), Ultimate TBI Mods,AFPR,MSD(ignition,coil&wires),Edelbrock TBI Manifold, 190ltr/hr fuel pump,
Eibach springs with KYB's all around,
Centerforce dual friction clutch
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops
0-60mph-7.0s-Gteched
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
[This message has been edited by 88'camaro305TBI (edited October 11, 2001).]
Old Oct 11, 2001 | 11:55 PM
Guest
Guest
Posts: n/a
Summit sells an inline one fairly cheap if you want a permanent one. Auto parts stores have gauges you can hook up just to check it that arent too terribly expensive since its not really high pressure like a TPI.
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
