Summit Rebuild Kits(Forged or Hypereutectic Pistons?)
Old Oct 11, 2001 | 06:34 PM
MetKiss316's Avatar
Hey guys. In my Summit Racing catalog, Summit overs an Engine Rebuild Kit for 1976-1993 Chevy 305(and many, many other engines, i might add.) Here are the specifics:
_____________________________________
Cast, Sterling Hypereutectic, or Speed Pro forged pistons
Speed Pro Piston Rings
Main, cam, and rod bearings
high volume oil pump
top quality gaskets
freeze plugs
Plastigage
assembly lube
Pistons, rings, rod and main bearings are available in standard bores and various oversizes. Compression ratios are calculated with .030 over pistons.
My engine was rebuilt around 96/97, but it has been sitting for about 2-3 years, only getting cranked about once a week until recently when I took control of it. I figure this would be a good step to returning the engine to a good condition, as it is currently bone stock. I plan on adding the Flowmaster American Thunder cat back, Catco high flow cat, and eventually Hooker Shortie Super Comp headers and a CompCam 264.
My question is what kind of pistons should i get, and what bore/size? What is best for my situation?
1987 Camaro Sport Coupe 305 V8 LG4-rebuilt-All Stock.
Old Oct 11, 2001 | 06:38 PM
MetKiss316's Avatar
BTW, compression for the forged pistons are 8.64:1
Hypereutectic is 8.39:1.
Old Oct 11, 2001 | 07:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
For that combo, I believe the hypers are adequate. Get flat-tops (L69) instead of dished (LG4), which should bump your CR up to around 9¼. I would also not recommend the HV oil pump; my favorite is the regular M55, with the Mr Gasket relief spring (part # 26). Bore for the pistons & rings, and the bearing sizes, will depend on the state of the block and crank you have; that's not necessarily something you can pick & choose.
ICON Motorsports
Old Oct 12, 2001 | 07:39 AM
ede's Avatar
ede
damnit rb beat me to it. hypers and standard volumn pump with a mr gasket #26 spring. with hypers make sure you read what the makers says about ring gap and make sure you check it.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
italiano67
Dec 11, 2016 09:21 AM
Magman
Sep 13, 2015 08:43 AM
Mickeyruder
Sep 2, 2015 02:45 PM
SlowAZ28
Aug 31, 2015 07:56 PM
someone972
Aug 30, 2015 12:52 AM
