main/rod bearings
Old Oct 12, 2001 | 10:38 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
main/rod bearings
hey guys my crank has been reground .10 on the mains and rods, for my new bearings do i assume they'll all be .10 over? anyone have a bearing recommendation that will withstand high rpms/racing?
86 Camaro with 88 305 LB9 using 86 carb setup, edelbrock performer manifold, 305 S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermostat, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Old Oct 12, 2001 | 11:04 AM
ede's Avatar
ede
if the crank has been ground .010 on the pins and mains you need .010 undersized bearings. i like clevite77 type bearings, i've use federal mogal and childs and albert
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
6speedIROC
16
Mar 15, 2023 08:33 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
