knocking sound coming from the motor
Old Aug 16, 2005 | 07:48 PM
Ironcross00024's Avatar
Car: 92 Camaro RS
Engine: 305 TBI - LO3
Transmission: 700R4 / 4L60
hello i just replaced the distributor cap and rotor plugs and wires
i used a accle cap and rotor and accle 8.8 wires and ac/delco riped fire plugs and now it its moakeing a knocking sound from the motor i checked the fireing order it it correct spark plug gap is correct. what could be the problem i need help. i bought this car for $500 dollars it was sitting for 3 years i put about 1200 dollars into it all ready an new trans all new suspention i drove it from Pa to GA with out a problem that is like 981 mile now thing seems to be acting up[ i just replaced the fuel pump today that is working fine now. is there anything else i should replace right away
thank u
Old Aug 16, 2005 | 08:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Sounds like you might be replacing the bearings.
italiano67
Dec 11, 2016 09:21 AM
Andrew6.688
Dec 13, 2015 10:59 AM
db057
Aug 22, 2015 08:17 PM
gwade12
Aug 8, 2015 08:17 AM
