another "wont start" question
Old Aug 17, 2005 | 01:42 PM
84camaroZ's Avatar
Car: 1984 Camaro Z28
Engine: LG4
Transmission: th-700
i just got back from Iraq and went to go pick up my Camaro from storage. When i got there the guy told me he was having problems with my batt the whole time i was gone. I went ahead and bought a batt, needed one anyway. he also said after he moved it up to the ready line he couldnt get it to turn over. I checked all the basics, im thinking its the coil. im fixin to go test the coil, i was just wandering if anyone had some other ideas of what it might be.
batt is good
fuel is pumping fine
cranks just fine
Just wont catch a spark!
Old Aug 17, 2005 | 01:44 PM
ChevyRacer's Avatar
Car: 86 Camaro Iroc-Z
Engine: 355 TPI
if coil is fine, check module the module. Try your best not to get an autozone/advance module. they seem to klast like a couple years then just die. Get a decent brand. Mine is by accell, but its an aftermarket performance replacement, not an oem get her running replacement.
If your coil and module check out then check your cap for extreme corrosion.
Old Aug 17, 2005 | 07:59 PM
84camaroZ's Avatar
Engine: LG4
ok here are my test results
TACH to BATT 0 OHM
TACH to SECONDARY infinite OHM
GROUND to SECONDARY 12-14 OHM
Hopefully someone can lead me in the right direction, my haynes book says to only replace it if both TACH to SECONDARY and GROUND to SECONDARY are both infinite
what do you think, maybe its not the Coil?
Old Aug 17, 2005 | 09:27 PM
ChevyRacer's Avatar
Engine: 355 TPI
verdict says, coil is good!
check module, take it to autozone, they test for free.
Old Aug 19, 2005 | 11:32 AM
84camaroZ's Avatar
Engine: LG4
bumb
Old Aug 19, 2005 | 11:46 AM
ChevyRacer's Avatar
Engine: 355 TPI
like ui said coil is good, but its never a bad thing to replace, newer is always better. with age resistance hgets higher. and things are less dependable. However those numbers say its good.
Get your module checked, Its no harder then removing the cap and rotor. Its right below the rotor in FI engines. If its carb, i dont know if there is a module still. Man, just noticed its an 84 as well.
Well, it doesn't get spark and coil is good. check your pickup. All the easy things first, before yiou start replacing things. Cant ever hurt anyways.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
