Need help with radiator, especially if you have a Be-Cool
Old Oct 12, 2001 | 06:04 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Well I was trying to install my Be-Cool radiator today and I'm having some major problems. First it won't really fit into the engine compartment right. It's too far over the the passenger side and I've already pounded the daylights out of the driver side radiator cradle seam. Any ideas on this one? Also it seems like it's way too high up. I can tell because the fan bolts don't want to line up. How can I make it lower?? I've heard of people cutting the mounts....what would I use to cut them and what part of the mount would I want to cut? Finally, about how large of a spacer did you guys have to use to move the fans away from the radiator and how much clearance should I have between the two? Thanks in advance guys. I would love to remedy this tomorrow. I'm getting so close now and these little things are killing me.
Riccioli Performance Motorworks
--RPM Racing--
Getting there.....383 with Super Ram, Bosch 24# SVO's, MSD, Edelbrock 58 mm TB, 700R4 tranny, Eibach springs, Koni 12 way adjustable shocks and struts, and more!! Now let's pray it runs when it's all back together!!!!
Old Oct 12, 2001 | 07:39 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Try Ames Performance Engineering. They have excellent Desert cooler 4 core Radiators. I was going to buy one, but they drop ship them out of California, and it takes 4-6 weeks for delivery. They are direct drop in radiators, so you won't have to do any mods. They are about $250 total, that is including the shipping. I just ended up getting a Modine Radiator locally around here that a few people on the board recommended. If your car isn't ready for the road for a little bit yet, this is the way to go, (in my opinion). Then this way you don't have to cut anything in your car. Either way, good luck man!
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Old Oct 12, 2001 | 08:03 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
my becool more or less dropped in. I did have to tilt it back a little but not much hammering was needed. I am using an twin SPAL electric setup that was made for the becool. I have about 2 inches between the waterpump pulley and the back of the fans.
Old Oct 12, 2001 | 11:31 PM
Car: 89 IROC-Z
Engine: 383
I'm running the stock fans. Anyone else have any input on this situation?
Old Oct 13, 2001 | 07:30 PM
cvpde37's Avatar
Sorry Paul, I can't imagine the problems you're having. My BeCool dropped right in with no modifications at all. It did sit a little higher, but it was less than an inch. When I first put mine in I used the original fan and rad hold down. I had new stuff made later on, but it was just for show and not function. Right now there is less than 1/4 inch between my Mr Gasket fan and the radiator.
1984 Z28 350
Never argue with an idiot, they'll just bring you down to their level and beat you with experience
My Web Page
Old Oct 13, 2001 | 09:16 PM
Car: 89 IROC-Z
Engine: 383
It's all good...I got it in finally!! Noting a little mini sledge hammer didn't fix. I had my rad support and cradle replaced when the motor and all were out so it was probably tweaked slightly. It's all lined up good now though. Thanks to everyone.
--RPM Racing--
Old Oct 13, 2001 | 09:42 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
When I installed mine, I made spacers out of some tubing, but you can use alot of different stuff, anyways, they were about 3/4" thick. Do you have an auto tranny, or manual? If you have auto, and unless they changed them, you will need an adapter for your tranny lines, which they don't tell you. Hope this helps...
KAM
sheachopper
Jul 31, 2019 11:27 AM
lanceflame44
Sep 25, 2015 12:28 PM
