Please help with MAP sensor (data inside)
Old Aug 18, 2005 | 09:21 AM
Dirty Dave's Avatar
Car: 85 Berlinetta
Engine: sort of working
Transmission: B&M 700R4
Within the past week I've gotten WinALDL working with my ZZ4 computer/chip & my 350. The MAP sensor data is not making sense. In fact it looks almost (but not quite) the inverse of what it should be doing at idle versus acceleration.
Here's data during idle (Park):
Code:
Time RAW:MAP RAW:BARO SENSOR:MAP SENSOR:TPS SENSOR:O2AVG SENSOR:MC Solenoid DC SENSOR:RPM SENSOR:BARO
0.6	177	232	75.7	      1.4	0.071	          51.4	          1100	    99.91
1.9	184	232	78.3	      1.4	0.473	          56.1	          1100	    99.91
3	180	232	76.8	      1.4	0.062	          50.6	          1125	    99.91
4.2	179	232	76.4	      1.4	0.367	          56.1	          1100	    99.91
5.4	180	232	76.8	      1.4	0.066	          51.4	          1100	    99.91
6.6	177	232	75.7	      1.4	0.597	          49	          1150	    99.91
7.8	187	232	79.4	      1.4	0.601	          53.7	          1075	    99.91
8.9	181	232	77.1	      1.4	0.513	          53.7	          1100	    99.91
10.1	182	232	77.5	      1.4	0.424	          53.3	          1125	    99.91
11.3	186	232	79	      1.4	0.583	          56.1	          1100	    99.91
12.5	179	232	76.4	      1.4	0.057	          50.2	          1075	    99.91
13.6	181	232	77.1	      1.4	0.296	          49	          1100	    99.91
14.9	182	232	77.5	      1.4	0.906	          51.4	          1075	    99.91
16	180	232	76.8	      1.4	0.685	          52.5	          1100	    99.91
17.2	180	232	76.8	      1.4	0.062	          49.4	          1150	    99.91
18.3	179	232	76.4	      1.4	0.327	          47.8	          1025	    99.91
19.6	174	232	74.6	      1.4	0.049	          43.1	          1075	    99.91
20.7	177	232	75.7	      1.4	0.455	          40	          1150	    99.91
21.9	186	232	79	      1.4	0.888	          46.3	          1075	    99.91
23	179	232	76.4	      1.4	0.256	          42.4	          1075	    99.91
24.2	181	232	77.1	      1.4	0.323	          45.5	          1125	    99.91
Here's data during steady cruise:
Code:
Time RAW:MAP RAW:BARO SENSOR:SPEED SENSOR:MAP SENSOR:TPS SENSOR:O2AVG SENSOR:MC Solenoid DC SENSOR:RPM SENSOR:BARO
61.3	187	232	       31	79.4	11	       0.853	       75.3	          1700	99.91
62.5	184	232	       31	78.3	11	       0.871	       75.3	          1700	99.91
63.7	184	232	       31	78.3	11	       0.888	       75.3	          1675	99.91
64.8	185	232	       31	78.6	11	       0.884	       75.3	          1725	99.91
66	185	232	       31	78.6	11	       0.902	       75.3	          1675	99.91
67.2	186	232	       31	79	11	       0.884	       75.3	          1700	99.91
68.4	187	232	       32	79.4	11	         0.897	       75.3	          1750	99.91
69.5	189	232	       32	80.1	11	       0.897	       75.3	          1775	99.91
70.8	190	232	       33	80.5	11	       0.871	       75.3	          1775	99.91
71.9	195	232	       33	82.3	8.7	       0.906	       75.3	          1600	99.91
73.1	219	232	       33	91.2	2	       0.857	       75.3	          1525	99.91
74.2	216	232	       32	90.1	1.4	       0.88	       75.3	          1625	99.91
75.5	200	232	       32	84.2	7	       0.911	       75.3	          1650	99.91
76.6	200	232	       32	84.2	7	       0.84	       75.3	          1650	99.91
77.8	200	232	       32	84.2	7	       0.893	       75.3	          1625	99.91
79	199	232	       31	83.8	7.6	       0.809	       75.3	          1650	99.91
80.2	195	232	       31	82.3	8.7	       0.813	       75.3	          1700	99.91
81.3	182	232	       31	77.5	13.8	       0.871	       74.5	          1775	99.91
and Here's data during heavy acceleration and decel after:
Code:
323.9	64	232	       37	34	95.4	       0.95	       39.2	          2625	99.91
325	37	232	       41	24	102.2	       0.99	       39.2	          2925	99.91
326.2	38	232	       47	24.4	102.2	       0.977	       39.2	          2875	99.91
327.4	37	232	       53	24	101.6	       0.968	       39.2	          3050	99.91
328.6	36	232	       59	23.6	101.6	       0.964	       39.2	          3350	99.91
329.7	35	232	       65	23.3	101.6	       0.941	       39.2	          3650	99.91
331	34	232	       70	22.9	101.6	       0.933	       39.2	          3925	99.91
332.1	35	232	       76	23.3	101.6	       0.928	       39.2	          4100	99.91
333.3	35	232	       80	23.3	101.6	        0.897	       39.2	          4225	99.91
334.5	35	232	       84	23.3	101.6	       0.897	       39.2	          4400	99.91
335.7	36	232	       88	23.6	101.6	       0.88	       39.2	          4675	99.91
336.8	38	232	       91	24.4	80.2	       0.906	       69.8	          4425	99.91
337.9	252	232	       91	103.3	1.4	       0.804	       74.9	          4100	99.91
339.2	252	232	       88	103.3	1.4	       0.716	       75.3	          4000	99.91
340.3	252	232	       84	103.3	1.4	       0.636	       75.3	          3950	99.91
341.5	252	232	       80	103.3	1.4	       0.743	       75.3	          3775	99.91
342.7	252	232	       77	103.3	1.4	       0.76	       75.3	          3600	99.91
343.9	252	232	       74	103.3	1.4	       0.499	       71.4	          3500	99.91
345.1	252	232	       71	103.3	1.4	       0.738	       75.3	          3350	99.91
346.2	252	232	       69	103.3	1.4	       0.791	       75.3	          3275	99.91
347.4	252	232	       66	103.3	1.4	       0.707	       75.3	          3150	99.91
348.6	252	232	       64	103.3	1.4	       0.911	       75.3	          3050	99.91
349.8	251	232	       62	103	1.4	       0.813	       75.3	          2925	99.91
350.9	250	232	       60	102.6	2	       0.844	       75.3	          2825	99.91
352.1	228	232	       58	94.5	11	       0.941	       75.3	          2750	99.91
353.3	248	232	       56	101.9	1.4	       0.88	       75.3	          2500	99.91
354.5	246	232	       53	101.1	1.4	       0.933	       75.3	          2150	99.91
355.6	238	232	       47	98.2	1.4	       0.95	       75.3	          1750	99.91
356.9	222	232	       39	92.3	1.4	       0.964	       75.3	          1475	99.91
358	205	232	       32	86	1.4	       0.968	       75.3	          1200	99.91
359.2	182	232	       24	77.5	1.4	       0.972	       75.3	          975	99.91
360.3	161	232	       18	69.8	1.4	       0.964	       75.3	          1075	99.91
If my calcs are correct, at idle the MAP says I'm running about 6.8 inHg. My mechanical gauge plugged into the manifold port shows a steady 17-17.5 inHg, which would be about 42kPa.
The acceleration also looks suspect since @ WOT there should be almost no vauum (ie. MAP near BARO). It's reading just the opposite!
This is a new MAP sensor from Advance Auto, GP Sorensen #77911509 for my '85. What I'm thinking of trying now is hooking up a vacuum hand pump to sensor and seeing what computer reads at various known vacuums. If that still doesn't make sense, I'm at a loss. I'm also wondering what effect these bad readings would have on my computer's performance.
Old Aug 18, 2005 | 11:32 AM
Damon's Avatar
Wait a minute. I see one of the columns is labeled "MC Solenoid". Is this a computer controlled carburetor induction system?
If so, you should know it doesn't have a MAP sensor, it has a VAC (vacuum) sensor which reads exactly the opposite way of a MAP sensor. This would certainly make everything make more sense, wouldn't it?
Old Aug 18, 2005 | 12:50 PM
Dirty Dave's Avatar
Car: 85 Berlinetta
Well, that's certainly news to me. My car ('85 Berl. LG4 originally, CCC yes) has both a BARO and MAP sensor, which from what I gather was not too common on 85's let alone those with carbs. I'll have to double-check my shop manual and make sure it really is MAP not vacuum. Even so, the 77 kPa sensor reading, if direct vacuum would correspond to about 22-23 inHg, still not even close to reality.
Like I mentioned before, I'm going to put some known vacuum on it tonight and post my results later. Maybe that will help figure things out more.
edit:
I searched the Advance Auto website again. Originally I requested parts for the 87 since that's what the ZZ4 computer is from. For 85's there is another sensor listed, but doesn't have the same hookup as mine. The new one I got just plugged right in. One's called a MAP the other is Manifold Differential Pressure. Now I'm wondering which one I need for the ZZ4 computer. Is it expecting MAP or vacuum or differential? Anyone have any experience with this?
Old Aug 19, 2005 | 06:20 AM
Damon's Avatar
Well, I know for sure that computer controlled carburetor setups from the factory definitely read the OPPOSITE of a MAP sensor. I'm beyond question about that. Whether it's called a VAC sensor or a Pressure DIfferential Sensor, I couldn't say without doing some research, but I recall it being called a VAC sensor off the top of my head. Might want to post up in the Carburetor section of this board instead of the general tech section. There's a few guys running around who know the computer systems for computer controlled carbs pretty well,
Of course, you're playing mix-n-match with the computer and sensor which complicates things considerably.
Old Aug 19, 2005 | 10:23 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Try subtracting your calculated kPa values from 100kPa and then see if they make more sense to you....
Old Aug 24, 2005 | 12:24 PM
Dirty Dave's Avatar
Car: 85 Berlinetta
I appreciate all the ideas, guys. Damon definitely put me on the right track.
What I did was measure what the computer was reading vs. actual input vacuum with a hand pump and gauge. Here's what I came up with:
Code:
Input Vacuum ("Hg)    MAP reading (kPa)
          0                                 21.4
          5                                 36
         10                                 53
         15                                 70.2
         20                                 87.4
         25                                 103.2
Indeed this seems to be a direct vacuum sensor! The curve fit of this data is extrememly close to the following equation which allows for exact conversion of the "MAP" reading in kPa to "Hg so you can have real-time manifold vacuum data like any other true MAP sensor:
Manifold Vacuum ("Hg)= (29.92/101.3)*kPa - (29.92/101.3)*20
or in simpler terms:
Man Vac "Hg = 0.295*kPa - 5.91
This actually matches my data well at idle of 76 kPa which converts to 16.5 "Hg!
I just hope this is the type of sensor the ZZ4 computer needs to see data from. I compared 2 "MAP" sensors from CCC quad cars and the output is virtually identical to what I found, so I'm taking that as a good sign.
Also, even though my car has a BARO sensor and all the proper wiring for it going to the computer, the computer either ignores it or only takes 1 reading right at key on because with the power on I varied the input vacuum on it too but the output didn't change.
I hope this is useful info to someone besides me
Old Aug 26, 2005 | 11:04 AM
Damon's Avatar
If that's the ZZ4 computer/chip that GM put out when they were selling a complete kit to replace old 305 computer controlled carburetor engines in 3rd gen f-bodys then it should work just fine. It was designed as a direct replacement for older 305s and was designed to work with all the original 305 sensors and such that were used on computer controlled carburetor engines- including the stock VAC sensor.
92firebirdguy
Sep 1, 2016 07:53 AM
customblackbird
Oct 1, 2015 04:30 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Ironhead38
Sep 7, 2015 02:26 PM
Eric-86sc
Sep 7, 2015 02:10 PM
