Burnt oil smell under hood
Old Oct 14, 2001 | 01:52 PM
91_305_Formula's Avatar
I have a burnt oil smell coming from under the hood. I'm not losing any oil..I check it regularly. Could this be the head gaskets or something like that? I just need some info to take into the shop with me. Any suggestions would be great. Thanks.
<A HREF="http://formula305.cjb.net" TARGET=_blank>http://formula305.cjb.net
</A>
1991 Formula 305TBI
3" Flowmasters
Hypertech Chip
3.42 Posi on the way
Old Oct 14, 2001 | 03:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's only one way to get teh smell of burnt oil, and that is ... {expectant drum roll please} ... to burn some oil.
You probably have a valve cover gasket that is leaking. It only takes a small amount of oil to make a noticeable smell; so it's entirely possible that you're not losing enough to be noticeable between changes but yet it could be enough to smell. VCs leak directly onto the top of the exhaust manifold where it bolts to the head, so even a very small leak will create the smell.
Another source of mystery oil smell is the timing cover seal, where the balancer goes through it. A leak there will come out onto the balancer which will then sling a fine mist of oil throughout the engine compartment, including the exhaust.
ICON Motorsports
Old Oct 14, 2001 | 04:43 PM
RODS92Z's Avatar
Yup, sounds like a valve cover leaking on to the exhaust manifolds.
1992 Camaro Z-28 custom 25th anniversary, 5.7 TPI auto, 2.73 posi, t-tops, arctic white with 92' medium mettalic gray stripes with black border stripe.
1967 Pontiac Catalina 2 door fastback, 400 v-8, auto, cameo white, dark red interior
1987 Olds Cutlass, 350 Rocket, auto, dark gray/light gray interior
Glowsock
Jul 24, 2025 03:15 PM
Street Lethal
Apr 30, 2019 12:14 PM
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
