What's the diff between an 1988 and 1989 TrottleBody?
Old Aug 20, 2005 | 12:16 PM
Fmandan's Avatar
Car: 1987 Formula 350
Engine: TPI 350
Also, can you make an 89 throttle body work on say an 87?
--Dan
Old Aug 20, 2005 | 04:32 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
1. I know the way the throttle cable hooks up is way different.
2. You would have to change the throttle cable to the later style.
Old Aug 20, 2005 | 04:38 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Also IAC passage (or is it EGR) is different on the 89-92's vs 88-down,
Heard you can swap newer ones on the old Plenum without issue, but not older ones on the newer plenums...only what I've gleened off the TPI board every so often, never tried it.
Old Aug 20, 2005 | 06:39 PM
Fmandan's Avatar
Engine: TPI 350
Thanks guys good info.--dan
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
