new to me 350 questions
Old Oct 14, 2001 | 12:12 AM
tacoboy's Avatar
Okay, I have a couple of questions, should be fairly simple. First of all, what can i find about my newly aquired engine (GM Goodwrench 350) and how? Theres numbers all over it, can you guys tell me somethin about my engine if I give you some of those numbers? Now on to my second question, this ones nice and specfic. I am going to be using the stock heads until later when I will purchase Vortec heads, id like a cam i can use with the stock heads, that will have enough grunt for the vortec. The Comp XE262 is highest on my list, how will that be with the stock heads? I'll be using some sort of intake that will be replaced by a GMPP vortec one later, Ill probably use a dualplane edelebrock performer for now with a Qjet on top of it. So, how will this cam do with this combo, mostly I want to know if it will be driveable. Thanks.
Old Oct 14, 2001 | 12:14 AM
Dauntless's Avatar
Just out of curiosity, because I'd like to buy a 350 TPI, what kind of gas mileage are you looking at with just the unmodified engine?
Old Oct 14, 2001 | 12:19 AM
tacoboy's Avatar
Sorry, don't even have it in yet, that's why I'm looking for cam recomendations now. I'm hoping for at least 15 though, we'll see.
Old Oct 14, 2001 | 10:56 PM
Enkil's Avatar
Around 30mpg isn't THAT hard to get with 305's or 350's, regardless of fuel delivery system. But that is modified. My unmodified 305 TBI gets about 22mpg on average, which is decent, but certainly not unheard of.
Check out mortec.com for information about the numbers all over the engine.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Oct 15, 2001 | 07:46 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I have the same exact motor, see sig. I get around 18 mpg. The only info. I can give you about the motor is redline is 5200 rpm. The HP max is 249 w/open headers, HEI,cast iron intake, and q-jet. TQ I believe is 304ftlbs. at 3200 rpm. I'm not sure but this site might give you more info., but I'm not sure if it is the right site or not. www.greenwoodcheverolet.com.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 15, 2001 | 08:08 AM
Car: 99 Formula
Axle/Gears: 342
Sorry the site doesn't work.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
