Knocking/ticking sound under 3000RPM
Old Aug 20, 2005 | 08:03 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I just bought a rebuilt 355 and put a CompCams XE268 flat tappet cam in it and broke it in. My car makes a ticking noise that goes up with RPMs as I accelerate until about 2500-3000RPMs.
It doesn't sound like rocker tick, but is it possible it could be lifter tick? Does lifter tick usually go away in the upper RPMs? I had followed the instructions in my CompCams cam install manual for setting lash. I went half turn past zero lash after soaking the lifters in oil and smearing cam lube on the pushrod ends and surface that contacts the cam.
Would a loose torque converter bolt do the same thing and go away by 3000RPM? Its a bit late tonight to do any work but I've been thinking about it a bit.
Also, if it is lifter tick, is there any possibility it will ruin the flat tappet cam that I have?
Old Aug 21, 2005 | 05:14 AM
Car: 1997 Corvette
Update on the situation. Was driving today and the knock all of a sudden stopped and my exhaust got a bit louder and one of my leaks got a lot worse. Maybe this was all exhaust-related afterall. I did seem to lose performance though as soon as this "knock" stopped, so maybe the exhaust is leaking bad enough all of a sudden to make a drop in performance? Mainly low end. It still pulls decent up top, but it has a lot less low end now.
Old Aug 21, 2005 | 05:55 AM
Vader's Avatar
Any exhaust leak can dilute the exhaust gasses that the O² sensor is supposed to sample.
With a significant change in sound and power production, I'd be tempted to pull the rocker covers and check the valve action just to make sure you're not wiping out a cam lobe.
Old Aug 21, 2005 | 10:54 AM
Car: 1997 Corvette
Yeah, that's the plan. I'll check it out tonight when I get home from work. I hope that cam's okay.
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
