Where is the fast idle relay located?
Old May 28, 2001 | 12:13 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
On a 86 carbed Z? thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old May 28, 2001 | 04:57 AM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
i thought it was next to the ******* relay?
Webmaster: www.IROC-Z.org
Old May 28, 2001 | 09:19 AM
BLACK Z's Avatar
Car: 86 Z28
What, did I say that yoiu did not under stand? is that not the name of it? I brought a relay and I am not sure which it is under the hood there are 2, that look the same, one is by the raditaor and the other is on the drivers side firewall.
Old May 28, 2001 | 11:40 AM
Engine: 305TPI
i thought you were screwing around...
one of them is a fog light relay i believe... get a wiring schematic and see what color the wires are..
sorry man,
Colin
Old May 31, 2001 | 09:59 PM
BLACK Z's Avatar
Car: 86 Z28
Where am I suppose to get one of them? thanks
Old Oct 16, 2001 | 12:10 AM
BLACK Z's Avatar
Car: 86 Z28
btt
Old Oct 16, 2001 | 08:44 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Hmmmm.....
There's no such thing as a fast idle relay. It's a carb. There's a choke thermostat, that works a bunch of linkage, one piece of which gets in the way of the throttle shaft from returning as far as it otherwise would when the choke thinks it's cold.
What are you really asking? That is, what does the car do that you don't like, or not do that you wish it did?
ICON Motorsports
Old Oct 16, 2001 | 09:10 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
There isn't a fast idle relay. As previously stated, the fast idle is a mechanical function of the carb. How long it stays on is determined by the electric choke coil. You have an electric choke relay, and an oil pressure switch above the oil filter in the electric choke circuit. What is the car doing that makes you think the relay is bad?
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Old Oct 17, 2001 | 12:52 AM
BLACK Z's Avatar
Car: 86 Z28
Well I was haveing a problem that I am not having anymore, and the dealer sold me this relay and I even seen it in the book, and that was what it was called, they will not take it back because it was a special order pieace so i figured I should just use it. Maybe I could get a part numbe rfor you? would that help? Thanks
db057
Aug 22, 2015 08:17 PM
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
