CTS and Fan Switch no work...properly.
Old Oct 17, 2001 | 04:34 PM
camaro6spd's Avatar
Ok, I just installed a CTS(for the gauges in the left side head and the fan switch in the rigth side head and the secondary fan has yet to come on, the primaray does gut never the secondary. The Gauge is all over the place....I turn teh einge on it it works, then i shut if off and turn it on and is says it is below or around 100, then shut it off and it will say wround 220, then right again, then not right several times then right....what is up with this?! I used teflon tape but not alont and left some treats to contact the head for a ground. I have just about had it with this car for the second time in a week.
Old Oct 17, 2001 | 05:08 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
eh, just dump that crap get a regular temp gauge and two toggles and flip them on when u want. i saves the hassle and looks cool inside with the toggles. kinda looks like u got nitrous but u dont u know?
86 berlinetta
350cui w/.30 over
.526 hilift cam
hooker supercomps
3" duals
edelbrock streetmaster
holley 750 dp
bad asshauler
Old Oct 17, 2001 | 07:40 PM
camaro6spd's Avatar
ok, i was watching the gauge very carfully after half-hearted cleaning(it's dark and cold outside) The gauge came up and read correctly for the first time and the i killed and restered the car and it came up about 20 degrees low but steadly increased as if that was the real temp. I think the wire or connection must be very dirty and adding resistance to it b/c it reads different temps some time but it will increase from there, kind of like some one was adding or removing different kinds of resisters inline every time. See what i mean. when we replaced the engine I routed the wires above the valve covers with out haveing to extend them(including the o2) so they are not buring up on a manifold. Any one know what to clean these things with...what if i solidered the connection? I could always unsolder it when it comes to replacing the sensor.
EDIT: I replaced the connection with a newer one, solidred a new clip on the wire and it still reads correctly orlow sometimes but you can watch the gauge heat up or sool down. Any suggestions?
[This message has been edited by camaro6spd (edited October 18, 2001).]
Bubbajones_ya
Jul 6, 2024 08:32 PM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
scotrans am
Sep 5, 2015 04:26 AM
85Special
Sep 3, 2015 04:21 PM
