New engine, synthetic OK?
Old Aug 25, 2005 | 12:13 AM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
I've heard in the past that you aren't supposed to use synthetic oil when you first put together an engine. Is this an old wives tale or not?
Old Aug 25, 2005 | 01:12 AM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
you should break it in with 10w-30. and go for a good 500miles and then switch to synthetic.
Just my 2cents
Old Aug 25, 2005 | 01:46 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I wouldnt use sythetic on break in. Works a little too good.
Old Aug 25, 2005 | 04:13 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Same as above, in fact unless its a hard used car and its getting real abuse, semi synthetic is more than suitable for most.
Old Aug 25, 2005 | 10:32 AM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Thanks for the tips guys, I think I'll be doing the 10w-30 break in.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
