Starting with a shortblock
Old Oct 16, 2001 | 10:14 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
What all would I need to get buy to build the rest of the engine. I know the most of it (Heads, cam, intake, carb(or whatever ones uses), pushrods, lifters, flywheel, cam and crank gears, timing chain,
I am looking at buying the ZZ4 shortblock and building on it (or just building up the 305) but money is an issue. I am just worried about buying a shrtblock, then when I get it together it blows up because I forgot a bolt or some small componet I never existed was not installed.
1 5/8 Hooker Competetion Headers, custom y-pipe,no cat, modified Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat, BF G-Force w-rated tires
Old Oct 17, 2001 | 07:55 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
A shortblock will include lifters, cam, and timing set.
You could include an aftermarket roller timing chain, but that requires removing the factory bottom gear and relacing it with a roller gear.
You will need an oil pump and pickup, oil pump drive.
Pickup location and oilpump drive are important but it is difficult to mess these up.
A good safety check is to primp the oil pump befor you put the motor in the car. Any lame mistakes will normally show up then.
Just go step by step. And pop to this board when you get stuck or have concerns.
Start looking on ebay for intake and maybe a set of heads.
[This message has been edited by jcb999 (edited October 17, 2001).]
Old Oct 17, 2001 | 09:29 PM
agawam's Avatar
why not buy the whole ZZ4 by the time you get the whole engine together you will have spent just about the same and the whole engine comes with a warrentee
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
