any one use that Gumout air intake and TB cleaner?
Old Oct 16, 2001 | 11:25 PM
86BIRD-MY FIRST CAR's Avatar
I was using this stuff cause i heard good things about it. As i was spraying this stuff into my throttle body while moving the butterfly valve back and fourth, the engine cut off after 4 seconds of direct spraying. the directions says spray 10 seconds wait 10 seconds, but as soon as i get to 4 seconds the engine stops. Is this normal??
86 firebird 2.8
K&N replacement filter
modified air box
MSD ignitor
Old Oct 17, 2001 | 10:40 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Yeah, that's what mine did too. Just spray it till the engine starts to sputter, then give it a few seconds and spray again. You're not hurting anything and it should clean out the carbon buildup pretty good.
Old Oct 18, 2001 | 02:26 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Hold the throttle open a little while you spray it in, it wont stall on you then.
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Dec 6, 2015 11:25 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
