RPM's stuck at 2.5K???
Old Aug 25, 2005 | 05:43 PM
87 LB9's Avatar
Car: 1987 Pontiac Trans Am
Engine: LB9
What is the deal with this? I did a power brake the other day, and the RPM;s stayed at 2,500 for about 5 seconds, then shot up... is there something wrong with my motor? Also the motor has 113K original miles on it, the thing is dead slow, 0-60 in 8 seconds? Is that what they should do?
Old Aug 26, 2005 | 09:44 AM
TurboGM1's Avatar
Car: 89 RS Camaro
Engine: 2.8 TPI
My 89 RS with the 2.8 V-6 has done the same thing. Both while power braking and with just driving. I got rid of the problem for the most part by replacing the TPS, IAC, and PCV valve. It drove great for about two or three weeks. No longer puttered, had more power back in it, wasn't stalling or dieseling, and wasn't getting stuck idling at 2,000 any more. But no once again it's doing it. I know I still need to replace the EGR valve and it's sensor or sending unit and I want to replace the O2 sensor with it, as this is a fuel injected car. Otherwise I can't figure out why it's doing it again. Did oil change, air filters, fuel filter, plugs, wires and cap and rotor on the distributor already to. After these last two parts to change, I'll be clueless as to what to do next. There's a chance it could be something simple. Anyone out there have any ideas on this??? Need help here.
Didn't mean to step on your thread, man. Just got a similar problem I thought I had fixed. One of the remedies I tried might work for you though.
RedLeader289
Sep 23, 2015 06:50 AM
camaronils
Sep 20, 2015 02:57 PM
wisemanz28
Sep 20, 2015 01:26 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
