Would New Higher lbs Injectors Help?
Old Oct 16, 2001 | 09:22 PM
Patrick007's Avatar
I have an open air intake and a flowmaster exhaust with no cat. So i know the motor is getting more air, so i'm assuming its gonna need more fuel. Its an 89 305 with TBI. What injectors are in there now and what would you reccomend for aftermarket injectors. Also, is there a truely precise may to figure out what injectors you really need or is this stuff just an educated guess? Thank
Patrick DeGrosse Jr.
Old Oct 16, 2001 | 09:23 PM
breathment's Avatar
im pretty sure the stock injectors will be able to keep up. wut about getting a Adjustable Fuel Pressure Regulator, if they will work on TBI's
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
[This message has been edited by breathment (edited October 16, 2001).]
Old Oct 17, 2001 | 09:16 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Check out my sig. After my mods my car was running too lean. I just popped a couple of stock 350 injectors in there and increased my power substantially. No more lean and no more knock counts. Since the stock 350 injectors are only about 10% larger than 305 I didn't mess with computer chip and everything seems fine. No gas mileage changes or anything like that.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Oct 18, 2001 | 01:50 PM
Patrick007's Avatar
Any other comments. Do u guys think I could be running a little lean with the exhaust and intake mods? Thanks
Old Oct 18, 2001 | 03:13 PM
rezinn's Avatar
I doubt it.
Bubbajones_ya
Jul 6, 2024 08:32 PM
webeeZ28
Sep 14, 2015 12:00 PM
Strick1
Sep 4, 2015 07:11 AM
