24lb injectors.. recommended fuel pressure
Old Aug 27, 2005 | 03:49 PM
FBoDyV85's Avatar
Car: 89 IROCZ Camaro
Engine: 350 w/ Boltons
I just put in 24lb ford racing injectors w/ a holly fuel pressure regulator in this morning. I was wondering what is the best fuel pressure to run these injectors at? Thanks for your input =)
-Steve-
Old Aug 27, 2005 | 04:15 PM
Untamed Z's Avatar
Need way more specifics on engine mods before anyone can "guesstimate".
Old Aug 27, 2005 | 04:23 PM
FBoDyV85's Avatar
its a stock remanufactured 350TPI. All i have on it are those injectors and 3" exhaust. Hooker 2055's, super comp catback, strait pipe cat.
Old Aug 27, 2005 | 06:35 PM
Untamed Z's Avatar
The 350 TPI's used 22 LB. injectors stock. I'm thinking they were set at around 43 PSI from the factory. I would start around there, and adjust it accordingly. If you don't have a local drag strip around where you can test and tune, you may have to go with the 'ol "seat of the pants" method. My guess would be around 47 PSI, but that's only a guess.
Old Aug 27, 2005 | 10:36 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
It depends if you are running MAF or SD. If MAF, by all means lower it until the injectors flow roughly 22lb/hr. If SD, you have some VE increasing mods which will need more fuel, but I still would say very close to 22lb/hr. The stock PE fueling is overly rich as it is, no sense in richening it up anymore.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
