engine timing and code 42 (EST Module)
Old Oct 18, 2001 | 07:02 PM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
well , just finished up changing all my vacuum lines, checked timing(6 degrees of advance) K&N filter charger, PCV valve, and air breather.....well #1, some bonehead before me shoved a small BB into one of the vaccum lines going to the egr valve.. huh, I guess that new egr valve i bought actually works now!! but, I am still getting a code 42 which is the EST electronic spark control.
Now saying that, I have to ask this....
I noticed when i unplug the tan/white wire to time my engine, the mark on the harmonic balancer stays dead on using a timing light. and when i turn the distributer it moves smoothly with retarding or advancing. Now, after I turn off the engine, and reconnect the wire, then restart the engine, then check timing again using the light, the mark kinda jumps around. Am I having issues here? Is the EST causing this? I cant seem to get a good time on this thing. My hesitation problem has really improved probably the bb in the vacuum removed, but, listening carefully as the car sits idleing, I notice everyonce in awhile I hear the engine or exhaust tone change from time to time like it is running alittle rough. So I thought maybe I have to much advance so I retard about a degree and start over. doesnt improve...Should I check the spark control module? Where is it, and can a reputable parts house check this for me on thier bench, or am I going in the wrong direction here? any suggestions......
<font face="Verdana, Arial" size="2">I have experience......unfortunatly its a result of bad judgement......</font>
click below to check out the new Formula Source....
www.theformulasource.com
or click below to check out my Formula350.......
www.formula350.com
or click below to email me
webmaster@theformulasource.com
[This message has been edited by formula90 (edited October 18, 2001).]
Old Oct 18, 2001 | 10:38 PM
Vader's Avatar
F90,
That is relatively normal. The ECM is using the EST to constantly adjust the ignition timing, "hunting" for the best value at a given RPM that won't produce detonation. The timing affects engine speed and MAP levels, so the marks will tend to wander a bit, bt should be significantly advanced from the base setting.
If you are having EST issues, check the electrical connections between the ECM and EST, the EST to the distributor, and the connection at the detonation sensor. You can temporarily disconnect the detonation (knock) sensor if you suspect that there is feedback from the sensor causing some of the timing problems. Remember that you have no knock protection with the sensor disconnected, so your ears may be the only things preventing damage from detonation. Try not to drive the car that way.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Oct 18, 2001 | 11:21 PM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
well Vader, I spoke to soon...
I guess maybe didnt give it enough advance because now the car is running rough again..
Let me get this straight.....
I am running a stock engine and my base timing is supposed to be 6 degres of advance..
if I turn the cap clockwise, does that advance or retard? advance right?
And when i retard or advance, engine rpm increases and decreases correct? menaing advance = higher rpm and vice versa? thanks in advance.. no pun intended
www.formula350.com
Old Oct 19, 2001 | 03:16 PM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
ttt
www.formula350.com
Frozer!!!
Jan 19, 2024 04:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
