Total timing advance problem
Old Oct 20, 2001 | 07:53 PM
wackytower's Avatar
Car: 1985 Trans Am
Engine: Superramed 406
Axle/Gears: 10 bolt 3:73
I am having a problem with my total advance. One time I check it I have 36* which is ok. Then the next time I check it, it goes to 45* advanced. I cant get to be consistant at all. I am using the factory 85 TPI distributor with 8* of intial timing. I'm thinking its in the distributor but would like any advise what to look for. Mods are in the sig.
1985 TA 700R4 w/stock converter and Transgo--9 bolt 3.27 rear 406 TPI--9.25 to 1 compression--ported stock intake, plenum--SLP runners--SLP cold air--trick flow 23* heads--compucam #2050--1.5 roller rockers--Accell 24lb injectors--
Ed Wright custom chip
Old Oct 20, 2001 | 11:17 PM
breathment's Avatar
there are many things wich affect timing, as long as the initial timming is always the same, the advance will be determined by such things as engine load, engine temp etc. try to check it under the same conditions.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
customblackbird
Aug 15, 2021 10:16 PM
Grant2k
Jul 10, 2018 04:01 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
