LT 1 cam, clear this up
Old Oct 20, 2001 | 04:22 PM
92blackbird's Avatar
Car: 1992 pontiac firebird
Engine: 305 tbi
I see alot of you using LT1 cams, or thinking about it. Do I understand it right, that I can use the LT1 cam with my stock valve train, (springs, lifters,etc.) and no other changes? If so what year cam should I be looking for or does someone have a specific part #. Sounds like a great mod but I want to be sure.
'92 firebird t-tops
305tbi,670cfm tbi, 2 1/2" Dynomax catback, 9x3 K&N open element
Old Oct 21, 2001 | 01:30 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Right, the LT1 cam has the right lift to not mess up your stock valvetrain. Any one should work, so hit up a 4th genner for his used one. Watch out for the dowel pin length on the front, you might have to cut or grind it down to match your stock cam.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Oct 21, 2001 | 06:12 AM
DM91RS's Avatar
Car: 91 RS
I replaced the peanut cam in my LO3 with the LT4 cam which is about the same as all the other LT1 cams. You do not have to replace anything else unless you want to. I would replace the timing set unless it's a low milage car. It pulls much better with the cam change.
91 RS 5.0 TBI....LT4 cam....Edelbrock headers....3"Dynomax exhaust....5spd.... 3.08.....Ultimate tbi....afpr...ZR 255-50's...Koni's
Old Oct 21, 2001 | 07:51 AM
Engine: 305 tbi
Thanks a lot. That's what I was hoping to hear. Now I can start hunting for one.
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Stryker412
Sep 7, 2015 09:11 AM
masonta
Sep 1, 2015 06:40 PM
