Compression braking bad for the engine?
Old Sep 1, 2005 | 02:37 AM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Yo guys, I live in the mountains, and on long downgrades, I usually shift into a lower gear and let the engine keep the car's speed down, instead of burning off my brake pads. In this mode, I don't let the engine rev over 3000 or so. Is this bad for the engine? I've been doing it for some time and the engine has not objected (so far). TIA.
Old Sep 1, 2005 | 03:40 AM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
I never hurt any of my cars by using engine braking, be it diesel turbos, 4 cyl petrol or V8s. However, you may get a blue cloud out of the exhausts when you go back on the power if the valve guide oil seals aren't up to the job
Mark.
Old Sep 1, 2005 | 12:54 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
every car I owned I do engine braking with from my I4 honda or celica, to my automatic v8 camaro even did engine braking up to my rotary mazda
not one has complained yet and the only car that really has a problem with it is my mazda gets a little smoke sometimes if I'm goosing it then go into engine braking but what can i say the car has over 200k miles on the clock
Old Sep 1, 2005 | 02:53 PM
Tremo's Avatar
Well, I do it all the time, and she don't smoke, so I guess it's not hurting anything, as long as you keep the RPMs reasonable.
The reason I ask is I read a thread on another forum that suggested that the very high vacuum you get when doing this was hard on pistons, rods and valves. One poster even went to far as to suggest that it may cause a rod to fail in tension, or pop the cap off.
Did the IROC engines use the PM rods?
Old Sep 1, 2005 | 03:13 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
No, regular old forged I-beams.
Old Sep 1, 2005 | 03:23 PM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Engine braking never does any harm.
As long as you dont drop it from 5th to 1st at 90mph.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
