Help me, where's the egr on this car?
Old Sep 2, 2005 | 09:09 AM
86FirebirdV8350's Avatar
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
1991 firebird v6/t5 where is the egr valve located? i need to replace it asap, the problem is clearly this part....please help....pictures would be greatly appreciated! thanks!
Old Sep 2, 2005 | 09:25 AM
llvll4l2c91350's Avatar
i know in the 2.8's its on the passenger side of the engine. pretty visible. may be in the same location on the 3.1's.
Old Sep 2, 2005 | 12:38 PM
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
yes it may be but i dont know what it looks like, anyone have a pic? its a 3.1L v6....thanks
Old Sep 2, 2005 | 02:27 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
its that UFO looking thing go to a parts store and ask to see the EGR vavle, then look for that onyour car
Old Sep 3, 2005 | 04:36 PM
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
i dont know where the hell this thing is i know what it looks like but where is it located??? does anyone have a picture?
Old Sep 3, 2005 | 10:55 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
it should be right in front of the dizzy
Old Sep 4, 2005 | 12:58 PM
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
i do not have a mechanical egr valve it is digital, if that helps....i dont believe it is near the distributor maybe the pass side in the middle??? would it be coming up from the exhaust manifold with a wire plugged in the top?
Old Sep 4, 2005 | 03:12 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
that would be your o2 sensor i believe, if what your looking at is on the exaust pipes then thats your 02 sensor. look to see if the EGR is at the front of the dizzy if it isnt then go out and get a haynes manual for 82-92 firebirds and it should tell you where it is in there.
Old Sep 4, 2005 | 04:12 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
It will be on the intake, as mentioned before, looks like an alien spacecraft...will have at least one vacuum line to it, and will/should have an electrical 2-wire connecter very close by for the solenoid.
Ghettobird52
Jul 5, 2024 11:18 PM
camaroken83
Aug 10, 2015 11:35 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
