Fuel Pump Removal? Easy Question
Hello. I am doing some replacement of parts on my 1985 Z28 Iroc, Carb TPI, and I can not seem to find my fuel pump. I know it's on block, but not sure where. I have the replacemnt, just need to know where the old one is. Anyone have directions as per removal? A diagram or good explanation would be most helpful.
Car: 4
Engine: 6
Transmission: 5
Bottom right corner of the block, on the side at the very front.
Remove threaded fuel line fitting from pump with a tubing nut wrench (a regular open end is likely to waste it); disconnect and plug the 2 rubber lines from the pump; remove the 2 bolts holding the pump on; clean gasket surface; installation is the reverse of removal. Make sure as you put the new pump in that the finger that sticks into the block goes up underneath the rod, not jammed up against it, which has a tendency to slide down as far as it can. The rod is a round piece of metal about ½" diameter.
ICON Motorsports
ICON Motorsports
<font face="Verdana, Arial" size="2">Originally posted by Drylar:
1985 Z28 Iroc, Carb TPI</font>
which is it? carb or TPI?
if it is carb then yes it is on the front passenger side of the block, if it is TPI then it is in the gas tank
Jay
Jay's Website
No car with 4 doors is a sports car! this goes back to my friend comparing his Maxima to a Camaro
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
that little pushrod is a pain; it will usually move its way down to the adapter plate and then you'll have to pull the plate off again in order to put the pump in correctly. this problem is solved by coating the rod in a heavy grease like white grease.
1987 LG4 Camaro z28
Performance
KN airfilter, flowmaster 80 series and catco high flow converter, 180* thermostat, edelbrock performer intake, msd blaster coil
System
Panasonic CQ-DF200U deck, fosgate speakers (hpc1369, frc2246), fosgate 400a4 amp
1987 LG4 Camaro z28
Performance
System
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
<font face="Verdana, Arial" size="2">Iroc, Carb TPI</font>
1 5/8 Hooker Competetion Headers, custom y-pipe,no cat, modified Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat, BF G-Force w-rated tires
92camaroJoe
Aug 13, 2015 06:07 AM
