EGR on AL L98 Heads
EGR on AL L98 Heads
I know that the heads do not have the EGR passage way. My question is this what do i need to do with my current egr valve if these heads do not have the passages? Also is there a way to run the EGR or eliminate it all together?
Any help, HELPS!!!!
Any help, HELPS!!!!
The heads not having an EGR passage essentially eliminates it permenantly.
Just bolt the EGR onto the manifold to keep the hole covered...it won't do anything else. You might throw an EGR code every once in awhile..but thats it.
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
Can't you make the EGR work with the Aluminum Corvette heads though?
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech Thermomaster chip with 160stat, MSD 6A, March Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's, Accell Universal 24# injectors
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
Car: 89 IrocZ
Engine: L98-ish
If you don't need to pass a visual for smog, only a functioanl test, route the EGR from a header tube or the exhaust manifold. Either will require a bit of drilling and tapping (manifold) or drilling and welding (headers). You can probably use a EGR valve from the Vette's?
I think Kevin91Z did this mod.
Keep in mind that you may not be able to do this, per your local smog laws.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yep I did. I modified my SLP headers and used a TPIS intake manifold with the Corvette EGR port and used a tube to connect the header to the intake manifold. I have pics I can post and show you tonight.
Edit: Scoggin Dickey has the kit now to make this work with their Vortec heads, its the same thing.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
[This message has been edited by Kevin91Z (edited October 23, 2001).]
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
